Accidentally removed src-folder
I accidentally removed my src-folder inside the catkin folder, instead of a single package. Is there any way to restore all the packages in the src-folder?
If you deleted the src, all the content in there is deleted forever. However, the original src structure can be recovered so you can start again from a fresh system:
In order to restore it, just log out and wait for 10 minutes. Next time you log in, the original src would have been restored
Adding to what @roalgoal said, we can also restore a previous version of your workspace.
If after coming back you do not find the files you want, you can let us know which of the following versions you would like to restore:
I would like to restore the version from Sept. 16, 10:15:35. Thank you!
The requested version has been restored.
