[Bug] rosrun command not running
something wrong with move_bb8_square.py: Unexpeted indentation (spaces in the script are marked as errors)
That means some indentation error was introduced when you copied the code.
Please copy the code again using the copy button at the top-right corner of the code block. Alternatively, you could also fix the indentation errors by adjusting the code in the Code Editor.
