# Cannot spawn Gurdy on Gazebo (quiz)
**URL:** <https://get-help.theconstruct.ai/t/cannot-spawn-gurdy-on-gazebo-quiz/4623>\
**Category:** URDF for Robot Modeling\
**Tags:** quiz, urdf, gazebo\
**Created:** [July 29, 2020, 9:59am UTC](https://get-help.theconstruct.ai/t/cannot-spawn-gurdy-on-gazebo-quiz/4623 "2020-07-29T09:59:17Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![jeferrandiz98](https://get-help.theconstruct.ai/user_avatar/get-help.theconstruct.ai/jeferrandiz98/32/1303_2.png) [@jeferrandiz98](https://get-help.theconstruct.ai/u/jeferrandiz98)\
**Post date:** [July 29, 2020, 9:59am UTC](https://get-help.theconstruct.ai/t/cannot-spawn-gurdy-on-gazebo-quiz/4623/1 "2020-07-29T09:59:17Z")
</div>
I try to spawn the gurdy urdf model on Gazebo using the methods of the previous unit but the robot does not appear on Gazebo. This is the .launch file I use (spawn\_gurdy.launch):
 <?xml version="1.0" encoding="UTF-8"?>
 <launch>
     <include file="$(find my_gurdy_description)/launch/spawn_urdf.launch">
         <arg name="x" value="0.0" />
        <arg name="y" value="0.0" />
         <arg name="z" value="0.5" />
         <arg name="urdf_robot_file" value="$(find my_gurdy_description)/urdf/gurdy_model.urdf" />
         <arg name="robot_name" value="gurdy" />
     </include>
 </launch>
and this is the spawn\_urdf.launch file I include in the previous one:
 <launch>
     <arg name="x" default="0.0" />
     <arg name="y" default="0.0" />
     <arg name="z" default="0.0" />
     <arg name="urdf_robot_file" default="" />
     <arg name="robot_name" default="" />
     <param name="robot_description" command="cat $(arg urdf_robot_file)" />
     <node name="urdf_spawner" pkg="gazebo_ros" type="spawn_model" respawn="false" output="screen"
     args="-urdf -x $(arg x) -y $(arg y) -z $(arg z) -model $(arg robot_name) -param robot_description"/>
 </launch>
The result I get on the terminal is this:
user:~$ roslaunch my_gurdy_description spawn_gurdy.launch
... logging to /home/user/.ros/log/86dbe4fe-d17e-11ea-a596-02977383c654/roslaunch-rosdscomputer-10276.log
Press Ctrl-C to interrupt
started roslaunch server http://rosdscomputer:32915/
SUMMARY
PARAMETERS
 * /robot_description: <?xml version="1....
 * /rosdistro: kinetic
 * /rosversion: 1.12.14
NODES
    urdf_spawner (gazebo_ros/spawn_model)
ROS_MASTER_URI=http://master:11311
process[urdf_spawner-1]: started with pid [10329]
the rosdep view is empty: call 'sudo rosdep init' and 'rosdep update'
SpawnModel script started
[INFO] [1596015833.930685, 0.000000]: Loading model XML from ros parameter
[INFO] [1596015833.933228, 0.000000]: Waiting for service /gazebo/spawn_urdf_model
[INFO] [1596015833.934656, 0.000000]: Calling service /gazebo/spawn_urdf_model
[INFO] [1596015834.030421, 621.292000]: Spawn status: SpawnModel: Successfully spawned entity
[urdf_spawner-1] process has finished cleanly
log file: /home/user/.ros/log/86dbe4fe-d17e-11ea-a596-02977383c654/urdf_spawner-1*.log
done
I have not added the controllers yet as I do not know how to continue and I do not understand the error.
Thank you in advance for your help
**Author:** ![simon.steinmann91](https://get-help.theconstruct.ai/user_avatar/get-help.theconstruct.ai/simon.steinmann91/32/324_2.png) [@simon.steinmann91](https://get-help.theconstruct.ai/u/simon.steinmann91)\
**Post date:** [July 30, 2020, 11:08am UTC](https://get-help.theconstruct.ai/t/cannot-spawn-gurdy-on-gazebo-quiz/4623/2 "2020-07-30T11:08:48Z")
</div>
There does not seem to be an error. You could try running a ‘roscore’ first in a different terminal and then executing your launch file. Also make sure that the robot description loaded correctly.
rosparam get /robot_description
**Author:** ![iv20023](https://get-help.theconstruct.ai/letter_avatar_proxy/v4/letter/i/a4c791/32.png) [@iv20023](https://get-help.theconstruct.ai/u/iv20023)\
**Post date:** [May 2, 2021, 9:32am UTC](https://get-help.theconstruct.ai/t/cannot-spawn-gurdy-on-gazebo-quiz/4623/3 "2021-05-02T09:32:50Z")
</div>
Robot will not be visible in Gazebo if you do not define inertial tags in urdf file. Why that fact is not clearly communicated in the lectures?
Igor V
