# How do I ensure turtle\_tf\_3d is available for import during catkin\_make?
**URL:** <https://get-help.theconstruct.ai/t/how-do-i-ensure-turtle-tf-3d-is-available-for-import-during-catkin-make/1201>\
**Category:** TF ROS 101\
**Created:** [October 25, 2019, 6:09am UTC](https://get-help.theconstruct.ai/t/how-do-i-ensure-turtle-tf-3d-is-available-for-import-during-catkin-make/1201 "2019-10-25T06:09:03Z")\
**Posts on this page:** 6\
**Page:** 1
<div class="post-metadata">
**Author:** ![SafdarKureishy](https://get-help.theconstruct.ai/user_avatar/get-help.theconstruct.ai/safdarkureishy/32/10_2.png) [@SafdarKureishy](https://get-help.theconstruct.ai/u/SafdarKureishy)\
**Post date:** [October 25, 2019, 6:09am UTC](https://get-help.theconstruct.ai/t/how-do-i-ensure-turtle-tf-3d-is-available-for-import-during-catkin-make/1201/1 "2019-10-25T06:09:04Z")
</div>
```auto
-- ~~ traversing 1 packages in topological order:
-- ~~ - tf_publisher
-- +++ processing catkin package: 'tf_publisher'
-- ==> add_subdirectory(tf_publisher)
CMake Warning at /opt/ros/latest/share/catkin/cmake/catkinConfig.cmake:76 (find_package):
  Could not find a package configuration file provided by "turtle_tf_3d" with
  any of the following names:
    turtle_tf_3dConfig.cmake
    turtle_tf_3d-config.cmake
  Add the installation prefix of "turtle_tf_3d" to CMAKE_PREFIX_PATH or set
  "turtle_tf_3d_DIR" to a directory containing one of the above files. If
  "turtle_tf_3d" provides a separate development package or SDK, be sure it
  has been installed.
  tf_publisher/CMakeLists.txt:10 (find_package)
-- Could not find the required component 'turtle_tf_3d'. The following CMake error indicates that you either need to install the package with the same name or change your environment so that it can be found.
CMake Error at /opt/ros/latest/share/catkin/cmake/catkinConfig.cmake:83 (find_package):
  has been installed.
-- Configuring incomplete, errors occurred!
See also "/home/user/catkin_ws/build/CMakeFiles/CMakeOutput.log".
See also "/home/user/catkin_ws/build/CMakeFiles/CMakeError.log".
Invoking "cmake" failed
I have the following in my package.xml file:
```auto
  <build_depend>turtle_tf_3d</build_depend>
  <build_export_depend>turtle_tf_3d</build_export_depend>
  <exec_depend>turtle_tf_3d</exec_depend>
And in CMakeLists.txt:
```auto
  rospy
  std_msgs
  turtle_tf_3d
And running rosdep for turtle\_tf\_3d:
```auto
user:~/catkin_ws$ rosdep where-defined turtle_tf_3d
ERROR: cannot find definition(s) for [turtle_tf_3d]
Searching for turtle\_tf\_3d:
```auto
user:~/catkin_ws/src$ rospack list | grep turtle
turtle_actionlib /opt/ros/latest/share/turtle_actionlib
turtle_tf /opt/ros/latest/share/turtle_tf
turtle_tf2 /opt/ros/latest/share/turtle_tf2
turtlesim /opt/ros/latest/share/turtlesim
… can’t find it.
What am I missing?
**Author:** ![ttqwer1](https://get-help.theconstruct.ai/user_avatar/get-help.theconstruct.ai/ttqwer1/32/10_2.png) [@ttqwer1](https://get-help.theconstruct.ai/u/ttqwer1)\
**Post date:** [October 28, 2019, 8:17am UTC](https://get-help.theconstruct.ai/t/how-do-i-ensure-turtle-tf-3d-is-available-for-import-during-catkin-make/1201/2 "2019-10-28T08:17:47Z")
</div>
I have the same problem and not fixed yet. Anyone can help?
**Post date:** [October 28, 2019, 8:20am UTC](https://get-help.theconstruct.ai/t/how-do-i-ensure-turtle-tf-3d-is-available-for-import-during-catkin-make/1201/3 "2019-10-28T08:20:34Z")
</div>
And by the way, this problem also occurs in Unit 4 Understanding Robot State Publisher & Joint State Publisher.
user:~$ roscd pi\_robot\_pkg
roscd: No such package/stack ‘pi\_robot\_pkg’
**Author:** ![duckfrost2](https://get-help.theconstruct.ai/user_avatar/get-help.theconstruct.ai/duckfrost2/32/9365_2.png) [@duckfrost2](https://get-help.theconstruct.ai/u/duckfrost2)\
**Post date:** [October 28, 2019, 3:13pm UTC](https://get-help.theconstruct.ai/t/how-do-i-ensure-turtle-tf-3d-is-available-for-import-during-catkin-make/1201/4 "2019-10-28T15:13:26Z")
</div>
I think its the same issue: [Problem of dependencies not found in TF 101 - Unit 2 and Unit 3](https://get-help.robotigniteacademy.com/t/problem-of-dependencies-not-found-in-tf-101-unit-2-and-unit-3/1230/2)
Please have a look at the answer and answer if it fixed something or not. If not please download the whole catkin\_ws with the IDE ( right click and download ), and share those files here so we can ha a look on what exactly is going on.
**Author:** ![ralves](https://get-help.theconstruct.ai/user_avatar/get-help.theconstruct.ai/ralves/32/7039_2.png) [@ralves](https://get-help.theconstruct.ai/u/ralves)\
**Post date:** [October 28, 2019, 6:36pm UTC](https://get-help.theconstruct.ai/t/how-do-i-ensure-turtle-tf-3d-is-available-for-import-during-catkin-make/1201/5 "2019-10-28T18:36:49Z")
</div>
Hi @ttqwer1,
I see the email you sent in which you mention the problem was solved after restarting your session, so I’ll mark this question as solved.
Thanks for letting us know you managed to make it work.
**Post date:** [November 3, 2019, 4:52am UTC](https://get-help.theconstruct.ai/t/how-do-i-ensure-turtle-tf-3d-is-available-for-import-during-catkin-make/1201/6 "2019-11-03T04:52:51Z")
</div>
Thanks everyone. This was very helpful. Yes, resetting the workspace fixed the issue.
