# Is "/" necessary for naming frames in ROS Noetic
**URL:** <https://get-help.theconstruct.ai/t/is-necessary-for-naming-frames-in-ros-noetic/15088>\
**Category:** TF ROS 101\
**Created:** [January 30, 2022, 9:43am UTC](https://get-help.theconstruct.ai/t/is-necessary-for-naming-frames-in-ros-noetic/15088 "2022-01-30T09:43:41Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![Joseph1001](https://get-help.theconstruct.ai/user_avatar/get-help.theconstruct.ai/joseph1001/32/7077_2.png) [@Joseph1001](https://get-help.theconstruct.ai/u/Joseph1001)\
**Post date:** [January 30, 2022, 9:43am UTC](https://get-help.theconstruct.ai/t/is-necessary-for-naming-frames-in-ros-noetic/15088/1 "2022-01-30T09:43:41Z")
</div>
In **ROS TF** , **Unit 3, Subscribe and Publish to TF** , program **model1\_to\_model2\_listener.py** , the goal is to listen to TF data and get one turtle to follow another turtle.
In the code, while naming the **frames** , **we add “/” before the frame name** as shown below:
```auto
follower_model_frame = "/"+follower_model_name
model_to_be_followed_frame = "/"+model_to_be_followed_name
I got the same result when I ran the code **without the “/”** , as shown below:
```auto
# follower_model_frame = "/"+follower_model_name
# model_to_be_followed_frame = "/"+model_to_be_followed_name
follower_model_frame = follower_model_name
model_to_be_followed_frame = model_to_be_followed_name
If the code works without the “/”, then why add it in the first place?
**Author:** ![duckfrost2](https://get-help.theconstruct.ai/user_avatar/get-help.theconstruct.ai/duckfrost2/32/9365_2.png) [@duckfrost2](https://get-help.theconstruct.ai/u/duckfrost2)\
**Post date:** [February 1, 2022, 9:21am UTC](https://get-help.theconstruct.ai/t/is-necessary-for-naming-frames-in-ros-noetic/15088/2 "2022-02-01T09:21:20Z")
</div>
Good question. So in theory the “/” in front states that you want that TF to have that name, no matter if it has a robot Namespace.
But namespaces in ROS1 are quite a buggy topic and in some systems, this works and some others doesn’t.
In the end it’s just to state that the name has to be /whatever, without the namespace
**Post date:** [February 1, 2022, 9:28am UTC](https://get-help.theconstruct.ai/t/is-necessary-for-naming-frames-in-ros-noetic/15088/3 "2022-02-01T09:28:59Z")
</div>
@duckfrost2
> [@duckfrost2](#):
When you say that its buggy in some systems, what do you mean by systems specifically? is it the Distro like Melodic or specific programs ?
**Post date:** [February 4, 2022, 8:52am UTC](https://get-help.theconstruct.ai/t/is-necessary-for-naming-frames-in-ros-noetic/15088/4 "2022-02-04T08:52:49Z")
</div>
I mean in ROS in general, some packages process correctly the namespacing and others don’t, to avoid that or at least be consistent we use this “/”.
