# Mark 4.0 but same code as solution
**URL:** <https://get-help.theconstruct.ai/t/mark-4-0-but-same-code-as-solution/7213>\
**Category:** ROS Control 101\
**Created:** [December 30, 2020, 12:19pm UTC](https://get-help.theconstruct.ai/t/mark-4-0-but-same-code-as-solution/7213 "2020-12-30T12:19:37Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![felix.hoffmann.vhh](https://get-help.theconstruct.ai/letter_avatar_proxy/v4/letter/f/7c8e57/32.png) [@felix.hoffmann.vhh](https://get-help.theconstruct.ai/u/felix.hoffmann.vhh)\
**Post date:** [December 30, 2020, 12:19pm UTC](https://get-help.theconstruct.ai/t/mark-4-0-but-same-code-as-solution/7213/1 "2020-12-30T12:19:37Z")
</div>
I tried the ROS Control 101 Quiz today multiple times. When I test my code everything is working fine but when I correct the quiz I get the mark 4.0 and I don’t know why so I opened the solution and I saw that my code was nearly the same as the code in the solution but I dind’t get a mark from 8.0 to 10.0.
I really want to get the certificate for the ROS Beginner Course.
Here you can find my code:
[quiz packages](https://www.transfernow.net/ddl/QuizROSControl)
Thank you very much.
Kind Regards
Felix
**Author:** ![albertoezquerro](https://get-help.theconstruct.ai/user_avatar/get-help.theconstruct.ai/albertoezquerro/32/7031_2.png) [@albertoezquerro](https://get-help.theconstruct.ai/u/albertoezquerro)\
**Post date:** [December 31, 2020, 9:54am UTC](https://get-help.theconstruct.ai/t/mark-4-0-but-same-code-as-solution/7213/2 "2020-12-31T09:54:34Z")
</div>
Hello @felix.hoffmann.vhh,
I’ve been testing the packages you sent me and I’m getting a mark of 10:
 ![Captura de pantalla 2020-12-31 a las 10.52.37](https://get-help.robotigniteacademy.com/uploads/default/original/2X/1/17e1f305e09f7dfa85ede9b64c9007d1e6a92ba5.jpeg)
Can you make sure you close all the programs you might have running in the Shells before correcting it?
**Post date:** [December 31, 2020, 2:06pm UTC](https://get-help.theconstruct.ai/t/mark-4-0-but-same-code-as-solution/7213/3 "2020-12-31T14:06:45Z")
</div>
Hi Alberto,
Okay, maybe there was a program running,
I would like to check that but actually I can’t access the courses anymore. My license is activated until 07.01. but when I try to open a course it says that I need to subscribe.
 ![Error](https://get-help.robotigniteacademy.com/uploads/default/original/2X/8/86d52279ce4d35af948a3076e4c6e751c167aec9.png) ![License](https://get-help.robotigniteacademy.com/uploads/default/original/2X/f/f9a91694ac4d37d00bcd0c91de4e34614ec1c01e.png)
**Post date:** [January 5, 2021, 9:08am UTC](https://get-help.theconstruct.ai/t/mark-4-0-but-same-code-as-solution/7213/4 "2021-01-05T09:08:22Z")
</div>
Let me redirect this issue to the proper team.
**Author:** ![bayodesegun](https://get-help.theconstruct.ai/user_avatar/get-help.theconstruct.ai/bayodesegun/32/10684_2.png) [@bayodesegun](https://get-help.theconstruct.ai/u/bayodesegun)\
**Post date:** [January 5, 2021, 10:05am UTC](https://get-help.theconstruct.ai/t/mark-4-0-but-same-code-as-solution/7213/5 "2021-01-05T10:05:32Z")
</div>
I have checked and found that you can access the courses with the License tied to this account. Did you login with the right account?
