On the actions quiz, Im getting the following error: '[16:06:49] [assess] Drone was not landed. You intend to keep it hanging in the air?
x - Is your code landing the drone correctly?
- Is your code taking the drone off after landing it? It should NOT. You should use the
TAKEOFF call for that.’
I am not calling TAKEOFF after landing the drone, and I have tested it manually (calling TAKEOFF followed by LAND in a separate webshell) several times, and it seems to be working exactly as expected. The logging is telling me the landing sequence is completed, and I see the drone landing in the simulation. However when I run the gradebot, it passes the test of calling LAND, but then I get this error and the drone is stuck in the air when I close it down. Since I can’t reproduce the error outside of the test, I don’t really know how to solve this. Thankful for any help
