ROS2 Navigation project: Bug? Error?
This is not terribly important and this post is meant to bring awareness.
When launching the simulation in the ROS Navigation rosject, the given commands are:
source ~/simulation_ws/install/setup.bash
ros2 launch turtlebot3_gazebo main_turtlebot3_lab.launch.xml
The source command returns this error.
user:~$ source ~/simulation_ws/install/setup.bash
not found: "/home/user/simulation_ws/install/turtlebot3_node/share/turtlebot3_node/local_setup.bash"
This error does not prevent the simulation from launching or running correctly. I thought I’d inform y’all about it.
@pharva
Thank you so much for reporting it, even if it seems to be not so important. We don’t want to have any errors, so please keep them coming!
I’ve captured this one for review.
