# ROS\_project\_part2
**URL:** <https://get-help.theconstruct.ai/t/ros-project-part2/9199>\
**Category:** ROS Basics In 5 Days (Python)\
**Created:** [April 2, 2021, 9:45am UTC](https://get-help.theconstruct.ai/t/ros-project-part2/9199 "2021-04-02T09:45:34Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![ToniSolo](https://get-help.theconstruct.ai/letter_avatar_proxy/v4/letter/t/e95f7d/32.png) [@ToniSolo](https://get-help.theconstruct.ai/u/ToniSolo)\
**Post date:** [April 2, 2021, 9:45am UTC](https://get-help.theconstruct.ai/t/ros-project-part2/9199/1 "2021-04-02T09:45:35Z")
</div>
Part 2 of basic ROS course project needs to call a service with an empty message. However, it also needs to read laserscan readings in order to execute the service routine. How can I call the service with empty message, but also provide the callback with LaserScan readings?
Here is a sample code below that may be close to what i am saying.
Assume a custom message with empty request.
I think something is wrong with the last lines, specifically at my\_service and sub.
Also ignore the routine inside the def callback.
I want to combine an empty message to just call the service once, but also insert LaserScan readings while service runs, to be able to execute its routine
from geometry\_msgs.msg import Twist
from sensor\_msgs.msg import LaserScan
from custom.srv import custom, customResponse
import time
def callback(request):
#length=len(msg.ranges)
#print('length: ',length)
print(msg.ranges[359])
print(msg.ranges[270])
print(msg.ranges[180])
print(msg.ranges[90])
print(msg.ranges[0])
if msg.ranges[180] \< 0.5:
move.linear.x = 0
move.angular.z = 0.25
time.sleep(1)
print(‘mode1’)
#pub.publish(move)
elif msg.ranges[90] \> 0.3:
move.linear.x = 0.1
move.angular.z = -0.25
time.sleep(1)
print(‘mode2’)
#pub.publish(move)
elif msg.ranges[90] \< 0.2:
move.linear.x = 0.1
time.sleep(1)
print(‘mode3’)
#pub.publish(move)
elif msg.ranges[90] \> 0.2 and msg.ranges[90] \< 0.3:
move.linear.x = 0.1
move.angular.z = 0
time.sleep(1)
print(‘mode4’)
#pub.publish(move)
pub.publish(move)
response = customResponse()
response.success = True
return response
rospy.init\_node(‘reach\_wall\_node\_service’)
my\_service = rospy.Service(’/reach\_wall’, custom, callback)
sub = rospy.Subscriber(’/scan’, LaserScan, callback)
pub = rospy.Publisher(’/cmd\_vel’, Twist, queue\_size=1)
move = Twist()
rate = rospy.Rate(1)
rospy.spin()
**Author:** ![roalgoal](https://get-help.theconstruct.ai/user_avatar/get-help.theconstruct.ai/roalgoal/32/7280_2.png) [@roalgoal](https://get-help.theconstruct.ai/u/roalgoal)\
**Post date:** [April 6, 2021, 8:19am UTC](https://get-help.theconstruct.ai/t/ros-project-part2/9199/2 "2021-04-06T08:19:44Z")
</div>
Hi, could you please format your code so I can take a better look at what you have? It’s difficult to see where functions start/end with this format. You can either share screenshots or use the “Preformatted text” button on the window where you type here in the forum. From what I can see here, you can consider separating the service call request and the callback and test your program. What behavior have you gotten with this code?
