the filestructe looks now like that
which is probably more clean
Volker
Volker
Hi @vkuehn ,
Just realized this error:
The solution, I guess, is simple. Delete your build
, install
and log
folders within ros2_ws
directory and redo
colcon build --packages-select wall_follower_srv wall_follower && source install/setup.bash
Let me know if this works now!
EDIT: Just added your service message package into the colcon build command line
no it doesn’t and shows the same error.
That is the interesting/strange/painful thing and I have shared the Copy ROS2 Basics Python Real Robot Project in hope the construct team can help.
Volker
EDIT: tried your edit also
Hi @vkuehn ,
Could you post your current setup.py
file contents for wall_follower
package please?
– Girish
Hi @girishkumar.kannan ,
here it is
from setuptools import setup
import os
from glob import glob
package_name = 'wall_follower'
setup(
name=package_name,
version='0.0.0',
packages=[package_name],
data_files=[
zip_safe=True,
maintainer='user',
tests_require=['pytest'],
entry_points={
'console_scripts': [
'wall_following = wall_follower.wall_following:main'
'wall_finder = wall_follower.wall_finder:main'
–Volker
Hi @vkuehn ,
Your problem seems to be strange! Your setup.py
file seems to be correct.
I tried to find your Copy ROS2 Basics Python Real Robot Project but I guess it is private.
I cannot view it, if you can check again and make it public, I can check it out and help you further!
EDIT: I have finished this course and got my certificate, so I can assure you that I will not steal any of your program. [Just wanted to say!]
I appreciate your help and would share it but it is complainin that it is a copy of a private one.
@albertoezquerro
you can probably find it as suggested.
If not I would save src, delete it, start a new copy.
Volker
Hi @vkuehn ,
Yeah, I just realized that. It said the same thing for me too! No problem!
Sorry I am unable to help you!
Cheers and Regards,
cheers @girishkumar.kannan
Hi @girishkumar.kannan, thank you very much for your great investigation in order to find that hidden character.
We will fix that error in the notebook.
@vkuehn, you mention that the launch file has:
package='wall_follower',
executable='wall_following',
and ~/ros2_ws/src/wall_follower/wall_follower/wall_following.py exists
Could you try to:
wall_following.py
instead of wall_following
in the launch filesource install/setup.bash
?@ralves ,
that adds .py to the erro message
launch.substitutions.substitution_failure.SubstitutionFailure: executable 'wall_following.py' not found on the libexec directory '/home/user/ros2_ws/install/wall_follower/lib/wall_follower'
I have downloaded src.
Can’t find the rosject in the public rosjects, would it be possible to get a fresh fork if I delete the existing one ?
regards
Hi @vkuehn ,
a fresh copy of the rosject can be taken from the link below:
Hi @ralves ,
that works and is kind of a solution. So starting from scratch there.
Thanks !
It also looks a bit different.E.g. the simulation has less obstacles so I hope I can make it through without bothering
Kind Regards,
Volker
