# Rviz2\_common and rviz2\_default\_plugins not found error in "How to visualize sensor data in ROS2" live class rosject
**URL:** <https://get-help.theconstruct.ai/t/rviz2-common-and-rviz2-default-plugins-not-found-error-in-how-to-visualize-sensor-data-in-ros2-live-class-rosject/27704>\
**Category:** General Support\
**Tags:** error\
**Created:** [December 7, 2023, 6:59am UTC](https://get-help.theconstruct.ai/t/rviz2-common-and-rviz2-default-plugins-not-found-error-in-how-to-visualize-sensor-data-in-ros2-live-class-rosject/27704 "2023-12-07T06:59:29Z")\
**Posts on this page:** 1\
**Showing post:** 4
<div class="post-metadata">
**Author:** ![phehjj](https://get-help.theconstruct.ai/user_avatar/get-help.theconstruct.ai/phehjj/32/7711_2.png) [@phehjj](https://get-help.theconstruct.ai/u/phehjj)\
**Post date:** [December 14, 2023, 5:22pm UTC](https://get-help.theconstruct.ai/t/rviz2-common-and-rviz2-default-plugins-not-found-error-in-how-to-visualize-sensor-data-in-ros2-live-class-rosject/27704/4 "2023-12-14T17:22:49Z")
</div>
Hi @sappari00 ,
I had spent some time trying the “How to visualize sensor data in ROS2” live class rosject myself and I found myself having the same issue as you.
I had chanced upon a similar problem via this post [Rviz\_common not found while launching rviz2](https://get-help.robotigniteacademy.com/t/rviz-common-not-found-while-launching-rviz2/23205)
It appears that this rosject ros 2 might be using the Crystal distro instead of dashing.
After I source crystal distro, I was able to run the launch file without the problem that you had mentioned:
source /opt/ros/crystal/setup.bash
Hopefully this answer solves your problem.
Regards,
Jing Jie
_[View the full topic](https://get-help.theconstruct.ai/t/rviz2-common-and-rviz2-default-plugins-not-found-error-in-how-to-visualize-sensor-data-in-ros2-live-class-rosject/27704)._
