While a node is running, I want to save all logs into a log file.
How can I do in ROS2 python?
Thanks
Thanks
Hi @NguyenDuyDuc ,
I would recommend you to have a look into this link: ROS2 Logging
There you can find things that can help you like setting an environment variable to a log file, accessing the default logging directory and writing/saving logs into a custom file.
