Hello everyone,
Here is my code for the quiz. I get 7/10 I would like to know what is the issue? Is my robot too slow and how slow? I did not want to use only my grate tests.
Here is the ERROR:
[09:10:49] [assess] The robot did NOT fully perform the expected movements. Is it too hard?!
- Did the robot move the right distance for each side of the two squares as stated in the notebook?
- Did the robot complete the movements within the stipulated time? (mark: 7)
from services_quiz.srv import BB8CustomServiceMessage, BB8CustomServiceMessageResponse
class MoveInSquare:
rospy.init_node('move_bb8_server')
self.my_service = rospy.Service('/move_bb8_in_square_custom', BB8CustomServiceMessage, self.my_callback) # create the Service called my_service with the defined callback
self.pub = rospy.Publisher('/cmd_vel', Twist, queue_size=1)
self.move = Twist()
rospy.loginfo("Service is ready")
rospy.spin() # maintain the service open.
def my_callback(self,request):
print("Request Data==> duration="+str(request.repetitions))
for i in range(request.repetitions):
for j in range(4):
# Move straight
self.move.linear.x = 0.2
self.move.angular.z = 0
self.pub.publish(self.move)
rospy.sleep(self.side_size(request.side)) # Move straight for 2 seconds
# Stop the robot
rospy.sleep(1) # Stop for 1 second
# Turn the robot
self.move.angular.z = 1.57 / 2 # Turn 90 degrees
rospy.sleep(2) # Turn for 2 seconds
# Stop the turn
rospy.loginfo("Completed side %d of square %d", j + 1, i + 1)
my_response = BB8CustomServiceMessageResponse()
my_response.success = True
return my_response # the service Response class, in this case MyCustomServiceMessageResponse
def side_size(self,side_length):
# Define the expected range of side lengths
min_side_length = 0.1 # minimum side length in meters
max_side_length = 10.0 # maximum side length in meters
# Normalize the side_length to the range [0, 1]
normalized_length = (side_length - min_side_length) / (max_side_length - min_side_length)
# Scale the normalized value to the range [0, 20] seconds
min_duration = 0.0
max_duration = 20.0
duration = normalized_length * (max_duration - min_duration) + min_duration
return duration
if __name__ == '__main__':
MoveInSquare()
