4.9 Services quiz
I have some problems with the quiz. The auto grader keeps timing out after:
[assess] services_quiz and services_quiz_srv packages compiled successfully (mark: 4.0)
I broke some of these off myself to spare some time but ow I am out of tries but the grade gotten is still at 0.0/10?
The steps seem to all work when I run them myself. Is it possible to see the logs of the autograder?
I’m facing the exact same issue :frowning:
First of all, we sincerely apologize for this error. It was an issue on our side related to a recent system integration, and we’re truly sorry it slipped through.
We’ve just uploaded a patch and verified that the grading system now returns a perfect score of 10 out of 10 using the correct quiz solution.
Please let us know if there’s anything we can do to support you or compensate for this mistake.
Best regards, Miguel Angel Rodriguez Head of Research and simulation integration
Thank you for your response. Could you reset my tries so I can check if my solution is correct?
And is there a way to see the logging of the gradebot for debugging purposes?
I’ve just reset your trials.
