Hello, getting Gradebot answer:
Action /distance_as is not publishing feedback. Didn't you know that feeback is a gift? Kindly look into this matter:
- Are you publishing feedback in your action server node?
- Call your action with ros2 action send_goal -f and check that you get feedback from the server.
But test shows that feedback is publishing:
What can be wrong?
Hi @shatodor,
Can you provide your node that is supposed to send the feedback ?
# scrubbed for learning reasons
It looks like the gradebot is not getting the feedback within the expected time (20 seconds).
I have fine-tuned the gradebot to wait a bit more for the action server feedback. Please check again and let us know.
No change. Same Gradebot answer.
Please bear with us while we look into this issue.
For some reason, the action server is not responding on time when called by the gradebot.
I submitted your quiz to the grader again and this time it passed! Thank you for your patience.
