7.9 Actions Quiz
Hi, I would like to dispute the grading of my ROS 2 7.9 Actions Quiz assignment.
I used all 5 of my attempts, and by my 3rd attempt my code was working as intended. The robot successfully reached the correct destination, but the grader did not mark the task as completed/correct.
I believe the issue may be with the grader rather than my ROS 2 code. Unfortunately, I have now used all 5 attempts, so I cannot submit another attempt to demonstrate this.
Could you please review my submission and the grading criteria/test results and consider manually checking my work?
Thank you.
So just to be clear about the issue: Is it in the ROS Navigation in 5 days course or the ROS Basics, or the ROS2 Basics action unit? Becuase I see you posted this in the Navigation course, but reffereing to actions.
