In the course notes for the above section it shows the below for the gazebo bridge node code
# ROS-Gazebo Bridge
gz_bridge = Node(
package="ros_gz_bridge",
executable="parameter_bridge",
name="gz_bridge",
arguments=[
"/clock" + "@rosgraph_msgs/msg/Clock" + "[gz.msgs.Clock",
"/cmd_vel" + "@geometry_msgs/msg/Twist" + "@gz.msgs.Twist",
"/tf" + "@tf2_msgs/msg/TFMessage" + "[gz.msgs.Pose_V",
"/odom" + "@nav_msgs/msg/Odometry" + "[gz.msgs.Odometry",
"/joint_states" + "@sensor_msgs/msg/JointState" + "[gz.msgs.Model",
remappings=[
# there are no remappings for this robot description
output="screen",
This did not work for me and I had to add the namespace of each robot to the topics I needed. The below worked for me. Was there a typo in the course notes or did I do something wrong?
"/robot1/cmd_vel" + "@geometry_msgs/msg/Twist" + "@gz.msgs.Twist",
"/robot2/cmd_vel" + "@geometry_msgs/msg/Twist" + "@gz.msgs.Twist",
"/robot1/odom" + "@nav_msgs/msg/Odometry" + "[gz.msgs.Odometry",
"/robot2/odom" + "@nav_msgs/msg/Odometry" + "[gz.msgs.Odometry",
"/robot1/joint_states" + "@sensor_msgs/msg/JointState" + "[gz.msgs.Model",
"/robot2/joint_states" + "@sensor_msgs/msg/JointState" + "[gz.msgs.Model",
