I’m in the second part of the rosject and i made two solutions and i like to ask wich one is the best or the right one.
First Option: No client(I don’t think this is the way because i think it’s a weird use of service, like a switch¿)
bool service_callback(std_srvs::Empty::Request &req,
std_srvs::Empty::Response &res) {
ROS_INFO("Service Called!");
service_called = true;
return true;
and then in the main it’s just:
while (ros::ok()) {
if (service_called && ( position > 375 || position < 345)) {
var.angular.z = 0.1;
} else {
service_called = false;
var.angular.z = 0.0;
ROS_INFO("Nearest Laser: %i", position);
pub.publish(var);
ros::spinOnce();
r.sleep();
position it’s just a global int that the subscriber callback is filling with the closest laser to a wall in ranges
**Second option: With Client ** (i think this one is what it’s supose to)
ROS_INFO("El minimo es: %i", position);
if ((375 < position || 345 > position)) {
return false;
} else {
return true;
the loop in the main is just:
while (ros::ok()) {
pub.publish(var);
ros::spinOnce();
r.sleep();
Client:
bool keepCallingService = true;
while (keepCallingService) {
if (move_robot_client.call(srv)) {
keepCallingService = false;
ROS_INFO("Service Ended.");
