About Error
Please tell me how to solve this error.
user:~/ros2_ws$ source install/setup.bash
ROS_DISTRO was set to 'foxy' before. Please make sure that the environment does not mix paths from different distributions.
ROS_DISTRO was set to 'noetic' before. Please make sure that the environment does not mix paths from different distributions.
not found: "/home/user/ros2_ws/install/turtlebot3_node/share/turtlebot3_node/local_setup.bash"
Please could you give more information?
  • Which course or rosject are you taking?
  • What unit of the course or section of the rosject are you working on?
Also, does this error prevent you from moving forward?
