About gazebo simulation
Gazebo is not working as it should.
I am getting the following error output.
Also, I cannot run the initial setup file.
Thank you very much for your help.
user:~$ source ~/simulation_ws/install/setup.bash
not found: "/home/user/ros2_ws/install/turtlebot3_node/share/turtlebot3_node/local_sher: symetup.bash"        efined suser:~$ ros2 launch turtlebot3_gazebo main_turtlebot3_lab.launch.xml
[INFO] [launch]: All log files can be found below /home/user/.ros/log/2024-05-11-12-opt/ros/36-00-089367-4_xterm-4644                                                           te_publi[INFO] [launch]: Default logging verbosity is set to INFO
GAZEBO MODELS PATH==/usr/share/gazebo-11/models:/usr/share/gazebo-11/models:/usr/sha
re/gazebo-9/models:/usr/share/gazebo/models_robox:/home/user/simulation_ws/install/t
urtlebot3_description/share:/home/user/simulation_ws/install/turtlebot3_gazebo/share
/turtlebot3_gazebo/models:/home/user/simulation_ws/install/turtlebot3_gazebo/share/t
urtlebot3_gazebo/maps/starbots_complete/models                                      in <moduGAZEBO PLUGINS PATH==/usr/lib/x86_64-linux-gnu/gazebo-11/plugins:/usr/lib/x86_64-lin
ux-gnu/gazebo-11/plugins::/home/user/simulation_ws/install/turtlebot3_description/li
b:/opt/ros/foxy/lib        .srv' (/urdf_file_name : turtlebot3_burger.urdf
[INFO] [gzserver-1]: process started with pid [4665]                                foxy/lib[INFO] [gzclient   -2]: process started with pid [4667]                             rtlebot3[INFO] [robot_state_publisher-3]: process started with pid [4669]                   0.01 --r[INFO] [spawn_entity.py-4]: process started with pid [4671]
[robot_state_publisher-3] /opt/ros/foxy/lib/robot_state_publisher/robot_state_publis undefinher: symbol lookup error: /opt/ros/foxy/lib/robot_state_publisher/robot_state_publis
her: undefined symbol: _ZNK12class_loader11ClassLoader14getLibraryPathB5cxx11Ev     /user/si[ERROR] [robot_state_publisher-3]: process has died [pid 4669, exit code 127, cmd '/.worldopt/ros/foxy/lib/robot_state_publisher/robot_state_publisher --ros-args -r __node:=r_init.soobot_state_publisher --params-file /tmp/launch_params_awh7cbih'].
[gzclient   -2] ++ ls /usr/bin/gzclient-11.5.1                                      '].
[gzclient   -2] + gzclient_path=/usr/bin/gzclient-11.5.1
[gzclient   -2] + DISPLAY=:2
[gzclient   -2] + /usr/bin/gzclient-11.5.1
[spawn_entity.py-4] Traceback (most recent call last):
[spawn_entity.py-4]   File "/opt/ros/foxy/lib/gazebo_ros/spawn_entity.py", line 28,
in <module>
[spawn_entity.py-4]     from gazebo_msgs.srv import DeleteEntity
[spawn_entity.py-4] ImportError: cannot import name 'DeleteEntity' from 'gazebo_msgs.srv' (/opt/ros/noetic/lib/python3/dist-packages/gazebo_msgs/srv/__init__.py)
[ERROR] [spawn_entity.py-4]: process has died [pid 4671, exit code 1, cmd '/opt/ros/foxy/lib/gazebo_ros/spawn_entity.py -entity burger -file /home/user/simulation_ws/install/turtlebot3_gazebo/share/turtlebot3_gazebo/models/turtlebot3_burger/model.sdf -x 0.0 -y 0.5 -z 0.01 --ros-args'].
[gzserver-1] gzserver: symbol lookup error: /opt/ros/foxy/lib/libgazebo_ros_init.so: undefined symbol: _ZN10gazebo_ros9ThrottlerC1Ed
[ERROR] [gzserver-1]: process has died [pid 4665, exit code 127, cmd 'gzserver /home/user/simulation_ws/install/turtlebot3_gazebo/share/turtlebot3_gazebo/worlds/realrobotlab_v1.world-s libgazebo_ros_init.so   -s libgazebo_ros_factory.so   -s libgazebo_ros_force_system.so       '].
[ERROR] [gzclient   -2]: process has died [pid 4667, exit code 255, cmd 'gzclient'].
Please could you give more information?
Which course or rosject are you taking?
What unit of the course or section of the rosject are you working on?
Also, does this error prevent you from moving forward?
