Action Servers and Clients - 7.5, 7.6
I am having trouble understanding the difference between ‘await’ and ‘add_done_callback’ covered while explaining Actions Client and Actions Server.
How do we know what structure of the code to follow between the two while building an algo? Is there a preferred method to use between them when it comes to Actions?
And in the below code, why do the callback functions have ‘async’ definitions? Does it do the same job as an asynchronous callback?
Ninad Mehta
#!/usr/bin/env python3
import rclpy
from rclpy.node import Node
from geometry_msgs.msg import PoseWithCovarianceStamped
from nav2_msgs.action import NavigateToPose
from rclpy.action import ActionClient, ActionServer
from tf_transformations import quaternion_from_euler
from action_msgs.msg import GoalStatus
import time
from leo_description.action import GoToPose
class MyActionServer(Node):
        super().__init__('my_action_server')
        # Action server to accept goals
        self.action_server = ActionServer(
            self, GoToPose, 'go_to_pose', self.execute_callback)
        # Publisher to set initial pose
        self.initial_pose_publisher = self.create_publisher(
            PoseWithCovarianceStamped, '/initialpose', 10)
        # Action client for navigation to pose
        self.nav_to_pose_client = ActionClient(
            self, NavigateToPose, '/navigate_to_pose')
        # Wait for the localization node to be ready
        self.wait_for_localization()
        # Set the initial pose to (0, 0, 0)
        self.set_initial_pose(0.0, 0.0, 0.0)
    def wait_for_localization(self):
        self.get_logger().info("Waiting for localization to be active...")
        amcl_pose_topic = '/amcl_pose'
        while not self.count_subscribers('/initialpose') > 0:
            self.get_logger().info("Waiting for subscribers to /initialpose...")
            time.sleep(1.0)
        while not self.topic_exists(amcl_pose_topic):
            self.get_logger().info(f"Waiting for {amcl_pose_topic} topic...")
            time.sleep(1.0)
        self.get_logger().info("Localization is active.")
    def topic_exists(self, topic_name):
        topics = self.get_topic_names_and_types()
        return any(topic[0] == topic_name for topic in topics)
    def set_initial_pose(self, x, y, yaw):
        """Publish the initial pose to the /initialpose topic multiple times."""
        initial_pose = PoseWithCovarianceStamped()
        initial_pose.header.frame_id = 'map'
        initial_pose.header.stamp = self.get_clock().now().to_msg()
        initial_pose.pose.pose.position.x = x
        initial_pose.pose.pose.position.y = y
        # Set the orientation as quaternion (for yaw rotation)
        q = quaternion_from_euler(0, 0, yaw)
        initial_pose.pose.pose.orientation.x = q[0]
        initial_pose.pose.pose.orientation.y = q[1]
        initial_pose.pose.pose.orientation.z = q[2]
        initial_pose.pose.pose.orientation.w = q[3]
        # Publish the initial pose multiple times
        for i in range(10):
            self.initial_pose_publisher.publish(initial_pose)
            self.get_logger().info(f"Publishing initial pose ({i+1}/10)")
            time.sleep(0.1)
        self.get_logger().info(f"Initial pose set to x: {x}, y: {y}, yaw: {yaw}")
    async def execute_callback(self, goal_handle):
        """Handle the incoming goal request."""
        self.get_logger().info('Received goal request')
        x = goal_handle.request.x
        y = goal_handle.request.y
        yaw = goal_handle.request.yaw
        self.get_logger().info(f"Navigating to: x={x}, y={y}, yaw={yaw}")
        # Send navigation goal
        result = await self.send_navigation_goal(x, y, yaw)
        if result:
            self.get_logger().info('Goal reached successfully!')
            goal_handle.succeed()
            return GoToPose.Result(success=True)
        else:
            self.get_logger().info('Failed to reach goal :(')
            goal_handle.abort()
            return GoToPose.Result(success=False)
    async def send_navigation_goal(self, x, y, yaw):
        """Send a navigation goal using the NavigateToPose action."""
        goal_msg = NavigateToPose.Goal()
        # Set goal position
        goal_msg.pose.pose.position.x = x
        goal_msg.pose.pose.position.y = y
        # Set goal orientation (yaw as quaternion)
        goal_msg.pose.pose.orientation.x = q[0]
        goal_msg.pose.pose.orientation.y = q[1]
        goal_msg.pose.pose.orientation.z = q[2]
        goal_msg.pose.pose.orientation.w = q[3]
        # Set the frame and timestamp
        goal_msg.pose.header.frame_id = 'map'
        goal_msg.pose.header.stamp = self.get_clock().now().to_msg()
        # Wait for the NavigateToPose action server
        self.get_logger().info("Waiting for the NavigateToPose action server...")
        self.nav_to_pose_client.wait_for_server()
        # Send the goal
        self.get_logger().info(f"Sending navigation goal to: x={x}, y={y}, yaw={yaw}")
        send_goal_future = self.nav_to_pose_client.send_goal_async(goal_msg)
        nav_goal_handle = await send_goal_future
        if not nav_goal_handle.accepted:
            self.get_logger().info('Navigation goal rejected')
            return False
        self.get_logger().info('Navigation goal accepted')
        # Wait for result
        get_result_future = nav_goal_handle.get_result_async()
        nav_result = await get_result_future
        if nav_result.status == GoalStatus.STATUS_SUCCEEDED:
            self.get_logger().info('Navigation succeeded')
            return True
        else:
            self.get_logger().info(f'Navigation failed with status: {nav_result.status}')
            return False
def main(args=None):
    rclpy.init(args=args)
    node = MyActionServer()
    try:
        rclpy.spin(node)
    except KeyboardInterrupt:
        pass
    node.destroy_node()
    rclpy.shutdown()
if __name__ == '__main__':
    main()
Hi @ninadmehta34 ,
Callbacks fire when the required event has occurred mostly used when you can not really predict when that particular event will occur. asynch functions using await on the other hand assign a job to be asynchronous but give you a bit of control on what to do if the result i.e. “future” isn’t available at the time. For what you are doing, you code looks fine to me. The trouble with await in some cases is that not further execution happens when in the await state. Add_done_callback however, can execute in non-async fushion without blocking when the result being waited for isn’t yet available. It proper non blocking behaviour. Whereas async with await is controlled async most useful if you want to the debugging process to be easier. Through it’s predictability.
Oh okay. Got it. Thank you!
