The NodeOptions in the constructor is needed only when you use the following lines:
The latter, as you noted:
Is actually sufficient as well, as mentioned in the rclcpp documentation. I have also tried this and it works for me too, so I can verify this. Yet, I still do not understand when exactly I would need the 4 additional lines in the create_client function. This is how it is mentioned in the official documentation also : Writing an action server and client (C++) — ROS 2 Documentation: Foxy documentation
I understand that the explicit keyword is necessary but the NodeOptions is not.
Although, as indicated in the documentation, you may construct the constructor as follows:
MyActionClient(const rclcpp::NodeOptions &node_options)
: Node("my_action_client", node_options)
bool goal_done_ = false; // you can add this line here to make the constructor line smaller
In my opinion, the concise version works the same way as the version with the four pointers to the node interfaces.
I would still like to know the reason as you do, from The Construct team.
I have not yet implemented actions (server or client) with node composition. That is probably the reason why I was unaware of this information and the use for NodeOptions.
Yes, I realized this soon after I posted my response. I forgot to edit/update it.
I realized that NodeOptions are required when I read through the unit on “Components” again.
I should have probably said that I have not implemented “Components” by myself. It was only during when I learned the unit on ROS2 Components. I have not tried to use Components in my programs yet (or in the course project).
Anyways, thanks for clarifying that point.
EDIT: Perhaps this reason for using NodeOptions could be added in the course with succinct lines, if not present in the course already, by The Construct team.
