How can I add new model inside the default .gazebo/models?
You just have to copy it to that folder. But for what exactly do you want to do it? I ask because depending on what , it wont give you the effect that you are searching for. In the ROSjects the models and *_description packages are copied automatically.
In the courses , its not meant to do it and therefore possibly wont work.
I was working on the duckietown autonomous driving project. However i was facing a difficulty with the road’s texture as the simulation is unable to load the road textures.
I tried to copy the model to .gazebo folder, also to change the model path but nothing worked.
Becaue ts solved I’ll set it as solved here: ISSUE
