Am I making the synchronous request correctly?
I am going through part 2.2 of the “ROS2 Basics Python Real Robot Project” and I need to add a synchronous request from the node I created to control the robot movement so the robots get positioned correctly by the find_wall service before starting to follow the wall. I did it as shown in the code below and it appears to be working all right, but I am unsure if it is correct. Can someone please check and correct me if necessary?
from find_wall.srv import FindWall
import rclpy
# import the ROS2 python libraries
from rclpy.node import Node
# import the Twist module from geometry_msgs interface
# import the LaserScan module from sensor_msgs interface
class Wall_following_node(Node):
        # Here you have the class constructor
        # call the class constructor
        super().__init__('wall_following_node')
        # create the publisher object
        # create the subscriber object
        self.subscriber = self.create_subscription(LaserScan, '/scan', self.laser_callback, QoSProfile(depth=10, reliability=ReliabilityPolicy.RELIABLE))
        # create the Service Client object
        # defines the name and type of the Service Server you will work with.
        self.client = self.create_client(FindWall, 'find_wall')
        # checks once per second if a Service matching the type and name of the Client is available.
        while not self.client.wait_for_service(timeout_sec=1.0):
            # if it is not available, a message is displayed
            self.get_logger().info('service not available, waiting again...')
        # define the timer period for 0.5 seconds
        self.timer_period = 0.25
        # define the variables to save the received info
        self.laser_forward = 0
        self.laser_right = 0
        self.lasers = []
        self.last_error = 0
        self.x = 0.0
        self.y = 0.0
        self.counter = 0
        # create a Twist message
        self.cmd = Twist()
        self.timer = self.create_timer(self.timer_period, self.motion)
        # create an FindWall request
        self.req = FindWall.Request()
    def send_request(self):
        # send the request
        self.future = self.client.call_async(self.req)
    def laser_callback(self,msg):
        #sim
        self.laser_forward = msg.ranges[0]
        self.laser_right = msg.ranges[540]
        #real
        #self.laser_forward = msg.ranges[360]
        #self.laser_right = msg.ranges[180]
    def motion(self):
        #Bang-Bang Control
        # if self.laser_forward > 0.5:
        #     self.cmd.linear.x = 0.1
        #     if self.laser_right > 0.3:
        #         self.cmd.angular.z = -0.15
        #     elif self.laser_right < 0.20:
        #         self.cmd.angular.z = 0.15
        #     else:
        #         self.cmd.angular.z = 0.0
        # else:
        #     self.cmd.angular.z = 1.0
        #PD control
        setpoint = 0.25
        error = setpoint - self.laser_right
            self.cmd.angular.z = 3*error + 20*(error-self.last_error)
        else:
        self.last_error = error
        # Publishing the cmd_vel values to a Topic
        self.counter = self.counter + 1
def main(args=None):
    rclpy.init(args=args)
    wall_following_node = Wall_following_node()
    #Run Syncronous request
    response = wall_following_node.send_request()
    print(response)
    rclpy.spin(wall_following_node)
    # Explicity destroy the node
    wall_following_node.destroy_node()
    rclpy.shutdown()
if __name__ == '__main__':
    main()```
No, you are not making a synchronous request here. You are making an asynchronous request. Please review the notebook again for the ways to make sync and async requests.
Just in case you’re confusing them:
  • Synchronous requests → you wait for the service to complete before going to the next line of the program. Use self.client.call
  • Asynchronous requests → you send the request and don’t wait for an answer. You check periodically if the request is done. Use self.client.call_async
Thank you for your answer @bayodesegun
I did the code again, this time using self.client.call but the code only works as expected when I use two threads. See the code below:
import rclpy
from rclpy.callback_groups import ReentrantCallbackGroup
        self.group1 = ReentrantCallbackGroup()
        self.wall_finder_client = self.create_client(FindWall, 'find_wall', callback_group=self.group1)
        while not self.wall_finder_client.wait_for_service(timeout_sec=1.0):
        self.subscriber = self.create_subscription(LaserScan, '/scan', self.laser_callback, QoSProfile(depth=10, reliability=ReliabilityPolicy.RELIABLE), callback_group=self.group1)
        self.lasers = []
        self.last_error = 0
        self.x = 0.0
        self.y = 0.0
        self.counter = 0
        self.cmd = Twist()
        self.state = "FIND_WALL"
        self.find_wall_response = False
        # send the request
        self.find_wall_response = self.wall_finder_client.call(self.req)
        #sim
        #real
    def motion(self):
        if self.state == "FIND_WALL":
            self.send_request()
            self.state = "FOLLOW_WALL"
        elif self.state == "FOLLOW_WALL":
            #Bang-Bang Control
            #     else:
            # else:
            #PD control
            setpoint = 0.25
            else:
    wall_follower_node = Wall_following_node()
    executor = MultiThreadedExecutor(num_threads=2)
    # Add the node to the executor
    executor.add_node(wall_follower_node)
    try:
        # Spin the executor
        executor.spin()
    finally:
        # Shutdown the executor
        executor.shutdown()
        wall_follower_node.destroy_node()
    rclpy.shutdown()
    main()
The code above works as expected, but I don’t understand why I must use two threads. The way I understand synchronous requests, when the program gets to the line self.send_request() the thread stops and only continues when the request is done. But When I use only one thread the thread stops and never continues, even after the request is done. The program gets blocked at the end of the request and never executes line self.state = "FOLLOW_WALL". Why?
Hi, I’ve had this same issue. I resorted to using asynchronous calls. It seems really strange that threads “die” (for lack of a better word) after being used in a synchronous call. Some clarification on this would be really helpful
Threads are tricky, and the sync call should run in its own thread in order not to block the main thread.
You just described the way ROS 1 services work. You don’t even need to call them in a separate thread, but ROS 2 sync service calls seem to be much more complicated. Async calls are much easier to work with as @AshK mentioned.
You must have been asked to do this as a sync call in order to learn a bit about how that works, and it’s good you now know how to make it work. Good job!
