Autocorrector for servers_quiz exercise
In my first attempt to submit my servers_quiz exercise I got an error since I typed wrong the service name. This happened to me because the service name was translated into Spanish and I asssumed it was “spin”, but actually it was “rotate”. So I corrected the service name to “rotate”, but in my second attempt I got the same error by the autocorrector, that the service name was wrong. Additionally, I do not know how exactly, but now I only have 2 attempts left instead of 3.
I have tested my server and my client together (before the first attempt, launching both server and client launch files) and it worked as it is supposed to. I would really appreciate any help by the support team since I do not want to run out of attempts :slight_smile:
If you need any more information about my issue, I would be glad to provide it.
Thank you!
Guillermo
OK! I just solved it. Thank you!
Could you please tell us how you solved it?
Hi!
Of course. Sorry, I didn’t explained it in detail in the second message since the solution was already “kind of” included in the first one. In the end, it was something about the name of the action server. Due to I am using the Spanish translation, I had some issues translating the action server name to English (I named it “/spin” when it was supposed to be called “/rotate”). Then, once I renamed correctly the server, the issue I had was with the autocorrect, maybe it was something about my cache, my internet connection or something similar. I think it was something like this because I re-run it today, after redoing some checking/testing, and everything worked perfectly.
I was running out of attempts, because in the second attempt I hit the button once and it counted as 2, so I had only two attempts left. Therefore, as advised in the platform, I opened this topic.
Thank you again! I love your platform :slight_smile:
Best!
