I provide reminders that may prevent the other students stuck with similar difficulties.
The cam_bot will not show in the simulation. In fifty times that I turn on the environment, I just see cam_bot once. The topic
robot_descriptionseems not working either. I think it may be related to the following errors. But, remember that the TF is always OK. You can see the robot’s bones (frames) in RVIZ2.
You need a launch file for this exercise. For one reason, there are not enough terminal windows. The first terminal may be ‘publish_static_transform_odom_to_world.launch.py’ for the World to Odom. The second is ‘cam_bot_odom_to_tf_pub’ for world to camera_bot_base_link. RVIZ2 is in the third terminal, and this exercise is in the last. There will be no terminal to send speed command to drive the cam_bot.
Don’t forget to add ‘use_sim_time’; otherwise, the following line will fail.
trans = self.tf_buffer.lookup_transform(
origin_frame,
dest_frame,
now)
I will paste my launch file.
#!/usr/bin/env python3
# Authors: Blue Bird
import os
from launch.launch_description_sources import PythonLaunchDescriptionSource
from launch.actions import DeclareLaunchArgument, ExecuteProcess, IncludeLaunchDescription
from launch.conditions import IfCondition, UnlessCondition
from launch.substitutions import Command, LaunchConfiguration
# Create the launch description and populate
ld = LaunchDescription()
cam_bot_odom_to_tf_pub_cmd = Node(
package='my_tf_ros2_course_pkg',
executable='cam_bot_odom_to_tf_pub',
name='cam_bot_odom_to_tf_pub',
output='screen',
parameters=[{'use_sim_time': True}])
ld.add_action(cam_bot_odom_to_tf_pub_cmd)
default_launch_file_path = os.path.join(get_package_share_directory('my_tf_ros2_course_pkg'), 'launch')
publish_static_transform_odom_to_world_cmd = IncludeLaunchDescription(
PythonLaunchDescriptionSource(
os.path.join(default_launch_file_path, 'publish_static_transform_odom_to_world.launch.py')
ld.add_action(publish_static_transform_odom_to_world_cmd)
move_generic_model_cmd = Node(
executable='move_generic_model',
name='move_generic_model',
output='screen',
ld.add_action(move_generic_model_cmd)
return ld
Keep it up, because the above things will not be enough.
The
rclpy.time.Time()is equivalent toself.get_clock().now(). They are not two different time sources. The professors that write the lecture are ROS masters. But, the novice, such as me, gets confused. -
In my experiment, the following line still fails.
origin_frame,
dest_frame,
now)
The error is about asking for a position that is not in the TF buffer. I make the following changes.
now = self.get_clock().now() - Duration(seconds=0.1)
trans = self._tf_database.lookup_transform(
target_frame=origin_frame,
source_frame=dest_frame,
time=now
Another way may ask for the latest transform in the TF buffer (time = 0).
In the function
calculate_coord, the professors useeuler_from_quaternion.
However, they usequaternion_from_eulerto transfer it back in functionmove_model.
It is useless computing from the viewpoint of programming. I think the professors just want to show the existence of these functions. -
Every member variable in the program is associated with a member function. For example, the variable
trans_speedis associated withset_translation_speed. It is a good habit of programming because in the member function you can do a validation check. But for me, it is confusing. I jump into a function just for one line of the code.
Take care of the extra comment, it is not related to the program. Just ignore them.
For ROS masters, I think they just scan the codes and know what they are doing immediately. For me, a novice, I need a story about the major flow of the program. Here is my story.
The program is focused on using the service called set_entity_state. It is automatically generated by a Gazebo plugin. The major function of this service is to set the pose or the state of an object in the Gazebo. It likes the magic that can move an object in the air. In this case, we set the pose of the cam_bot to the turtle_attach_frame. So, the cam_bot seems to follow the turtle.
To this end, we need to solve two difficulties. The turtle is moving, so the pose of the frame turtle_attach_frame is changing. To update the latest frame pose, we need a timer. In the meantime, the timer can also send the request to the service set_entity_state to move the cam_bot. However, there is another difficulty. Solving the turtle_attach_frame needs a TF buffer. Since it is a buffer, it needs an update. So, you need a TF listener.
I try to clean the code. Here is my code.
We should pub:
ros2 topic pub /destination_frame std_msgs/msg/String "data: 'turtle_attach_frame'"
from rclpy import Future
import rclpy
from rclpy.node import Node
from rclpy.duration import Duration
from rclpy.qos import QoSProfile
from tf2_ros import TransformException
from tf2_ros.transform_listener import TransformListener
from tf2_ros.buffer import Buffer
from std_msgs.msg import String
from geometry_msgs.msg import TransformStamped
from geometry_msgs.msg import Pose, Twist
from gazebo_msgs.msg import EntityState
from gazebo_msgs.srv import SetEntityState
class CamBotMove(Node):
def __init__(self, node_name: str):
super().__init__(node_name=node_name)
self._tf_database = Buffer()
self._tf_listener = TransformListener(self._tf_database, self)
qos_profile = QoSProfile(depth=1)
self._command_receiver = self.create_subscription(
String, '/destination_frame', self.process_received_destination_frame, qos_profile=qos_profile)
self.get_logger().info(f"The node {self.get_name()} is ok.")
self._flash_destination_timer = self.create_timer(
timer_period_sec=0.05, callback=self.flash_destination_send_command)
self._model_name_to_move = "cam_bot"
self.objective_frame = "camera_bot_base_link"
self._gazebo_set_entity_state_client = self.create_client(
SetEntityState,srv_name="/cam_bot/set_entity_state")
if self._gazebo_set_entity_state_client.wait_for_service(10) is False:
self.get_logger().error(f"Gazebo service /cam_bot/set_entity_state is not ready.")
raise RuntimeError
def flash_destination_send_command(self):
coordinates_to_move_to = self.get_model_pose_from_tf(
origin_frame="world", dest_frame=self.objective_frame)
if coordinates_to_move_to is None:
return
self.move_model(coordinates_to_move_to)
def process_received_destination_frame(self, msg: String):
self.get_logger().info(f"Receive objective frame {msg.data}")
self.objective_frame = msg.data
def get_model_pose_from_tf(self, origin_frame="world", dest_frame="camera_bot_base_link"):
Extract the pose from the TF
try:
time=now
return trans
except TransformException as ex:
f"Error when transform {dest_frame} into {origin_frame}: {ex}")
return None
def move_model(self, coordinates_to_move_to: TransformStamped):
destination_state = EntityState()
destination_state.name = self._model_name_to_move
destination_state.reference_frame = coordinates_to_move_to.header.frame_id
destination_pose = Pose()
destination_pose.position.x = coordinates_to_move_to.transform.translation.x
destination_pose.position.y = coordinates_to_move_to.transform.translation.y
destination_pose.position.z = coordinates_to_move_to.transform.translation.z
destination_pose.orientation.x = coordinates_to_move_to.transform.rotation.x
destination_pose.orientation.y = coordinates_to_move_to.transform.rotation.y
destination_pose.orientation.z = coordinates_to_move_to.transform.rotation.z
destination_pose.orientation.w = coordinates_to_move_to.transform.rotation.w
destination_state.pose = destination_pose
twist = Twist()
twist.linear.x = 0.0
twist.linear.y = 0.0
twist.linear.z = 0.0
twist.angular.x = 0.0
twist.angular.y = 0.0
twist.angular.z = 0.0
destination_state.twist = twist
request_msg = SetEntityState.Request()
request_msg.state = destination_state
future_set_entity_state = self._gazebo_set_entity_state_client.call_async(request_msg)
future_set_entity_state.add_done_callback(self._callback_set_entity_state_response)
def _callback_set_entity_state_response(self,future:Future):
try:
response = future.result()
self.get_logger().info(f"Gazebo robot returns: {response}.")
except Exception as e:
self.get_logger().error(f"Call gazebo_set_entity_state encounter error: {e}")
def main():
rclpy.init()
node = CamBotMove("force_move_cam_bot")
try:
rclpy.spin(node)
except KeyboardInterrupt:
node.destroy_node()
rclpy.shutdown()
if __name__ == "__name__":
main()
