I get the following message when I execute the following …how to clear this
user:~/catkin_ws/src/linux_course_files/move_bb8_pkg/my_scripts$ ./bash_script.sh
./bash_script.sh: line 5: [: ==: unary operator expected
./bash_script.sh: line 8: [: ==: unary operator expected
./bash_script.sh: line 11: [: ==: unary operator expecte
ralves
April 24, 2020, 10:37am
2
Hi @bandu2356 ,
it seems that you are referring to an empty variable without escaping it.
I could reproduce your error with the following code:
empty_var=
if [ $empty_var = "value" ]; then echo condition ok; fi
which gives me:
bash: [: =: unary operator expected
If we just put $empty_var between double quotes "$empty_var", then it works:
if [ "$empty_var" = "value" ]; then echo Condition ok; fi
This will not give an error.
After making the changes as mentioned by you i am getting this error
/dynamic.sh: line 5: [ : command not found
./dynamic.sh: line 8: [ : command not found
./dynamic.sh: line 11: [ : command not found
ralves
November 18, 2020, 12:16pm
4
Hi @ramku31 ,
then you probably forgot to put the “if” before the “[”. Are you still having the problem?
If so, could you send me your code as a private message?
I too have the same issue that @bandu2356 has. IDK what to do to rectify it…
ralves
November 27, 2020, 12:00pm
6
Hi @azeem00716 ,
have you tried the solution proposed above?
empty_var=
which gives me:
If we just put $empty_var between double quotes “$empty_var”, then it works:
Hi
i am having the same problem using the copy paste of the code from the course:
#!/bin/bash
ARG1=$1
if [ $ARG1 == 'forward' ]; then
rostopic pub /cmd_vel geometry_msgs/Twist "linear:
x: -0.1
y: 0.0
z: 0.0
angular:
x: 0.0
y: 0.0
z: 0.0"
elif [ $ARG1 == 'rotate' ]; then
x: 0.0
y: 0.0
z: 0.0
angular:
x: 0.0
y: 0.0
z: 0.2"
elif [ $ARG1 == 'stop' ]; then
x: 0.0
y: 0.0
z: 0.0
angular:
x: 0.0
y: 0.0
z: 0.0"
fi
i get the folowing:
./demo.sh: line 5: [: ==: unary operator expected
./demo.sh: line 15: [: ==: unary operator expected
./demo.sh: line 25: [: ==: unary operator expected
i was having the same isue in the exam took me a while to trial and error what was wrong i think it has something to do with spaces? but since it is in a course a copy paste should work?
ralves
December 15, 2020, 11:56am
8
Hi @ziga.rupret ,
if it is a copy-paste and didn’t work, then it is probably because you didn’t pass any param to the script.
You have to call it like:
./my_script.sh rotate
Instead of only
./my_script.sh
yeah that was it, Jesus how could i missed that
