When I call the rosservice call /request_measurement_update, the belief values are not changeing.
Could it be due to the fact that I have red indicators throughout my notebook?
Hello @bitcloude, welcome to the community!
those red, yellow or blue squiggly or wavy lines that appear beneath your code indicate a warning or syntax error, but they are not always perfect. In this case it the yellow wavy lines are a warning about using a global variable since global variables are generally discouraged as programming practice. In this case these warnings should not have an impact the correct functionality of the code.
Please compare your code with the script that I provide bellow ans see if you can spot any differences compared with your current version of the script.
Note: This is not the full script, just the script up until exercise 2.7 which is where you are stuck at the moment.
#!/usr/bin/env python
@author Roberto Zegers
@brief Discrete Bayes Filter Algorithm ROS Node
@date July 03, 2020
@license License BSD-3-Clause
@copyright Copyright (c) 2020, Roberto Zegers
from std_msgs.msg import Int32
from std_srvs.srv import Empty, EmptyResponse
# For Rviz visualization
from visualization_msgs.msg import Marker
from geometry_msgs.msg import Quaternion, Pose, Point, Vector3
from std_msgs.msg import Header, ColorRGBA
### Add initial belief HERE ###
belief = [0.1, 0.1, 0.1, 0.1, 0.1, 0.1, 0.1, 0.1, 0.1, 0.1]
### Add corridor map HERE ###
corridor_map = [0, 1, 0, 1, 0, 0, 0, 1, 0, 0]
# change these values modifying ROS parameters
kernel = [.1, .8, .1]
light_sensor_accuracy_rate = 0.9
bayes_filter_iteration = 0
# Global, for Rviz Markers
marker_publisher = rospy.Publisher(
'visualization_marker', Marker, queue_size=10)
### likelihood function ###
def likelihood(environment_map, z, z_prob):
""" Calculates the likelihood of each grid cell given the sensor's reading """
likelihood = [1] * (len(environment_map))
for index, grid_value in enumerate(environment_map):
if grid_value == z:
likelihood[index] *= z_prob
else:
likelihood[index] *= (1 - z_prob)
return likelihood
def likelihood(world_model, z, z_prob):
""" Calculates likelihood that a measurement matches a positions in the map """
# create output vector
likelihood = [1] * (len(world_model))
for index, grid_value in enumerate(world_model):
if grid_value == z:
else:
return likelihood
### Add normalize function HERE ###
def normalize(inputList):
""" calculate the normalizer, using: (1 / (sum of all elements in list)) """
normalizer = 1 / float(sum(inputList))
# multiply each item by the normalizer
inputListNormalized = [x * normalizer for x in inputList]
return inputListNormalized
### Add correct_step function HERE ###
def correct_step(likelihood, belief):
output = []
# element-wise multiplication (likelihood * belief)
for i in range(0, len(likelihood)):
output.append(likelihood[i]*belief[i])
return normalize(output)
### Add predict_step function HERE ###
def print_belief():
""" Prints current belief to console """
print("\nProbabilities of the robot presence at every grid cell:")
for idx, prob_value in enumerate(belief):
print("Grid cell %d probability: %f" % (idx, prob_value))
print("\n")
m_values = max(belief)
max_probability_grid_cells = [
i for i, j in enumerate(belief) if j == m_values]
print("Current position best estimate %06.4f %%, corresponding to grid cell(s):" % (
m_values*100))
print(max_probability_grid_cells)
print("\n")
# Callback function to handle new movement data received
def movement_callback(movement_data):
global belief
global bayes_filter_iteration
bayes_filter_iteration += 1
print("-----------------------------------------------------\n")
print("Bayes filter iteration: %d" % bayes_filter_iteration)
print("Movement data received: '%d'" % (movement_data.data))
### ADD BAYES FILTER PREDICT STEP HERE ##
### Visualize in Rviz ###
# create_rviz_markers(marker_publisher, belief)
# Callback function to handle new sensor data received
def sensor_callback(sensor_data):
global belief
print("Light sensor data received: '%d'" % (sensor_data.data))
### ADD BAYES FILTER CORRECT STEP HERE ###
# Print current belief to console
print_belief()
##### RVIZ MARKERS ########
def create_rviz_markers(marker_pub, dist):
for idx, prob_value in enumerate(dist):
# print("Grid cell %d probability: %f" % (idx, prob_value))
text_marker = Marker(
type=Marker.TEXT_VIEW_FACING,
id=idx,
lifetime=rospy.Duration(0),
pose=Pose(Point(-4.5+idx, 0.0, 0.15+prob_value*10),
Quaternion(0, 0, 0, 1)),
scale=Vector3(0.01, 0.01, 0.4),
header=Header(frame_id='map'),
color=ColorRGBA(0.0, 1.0, 0.0, 0.8),
text=str(prob_value)[:5])
marker_pub.publish(text_marker)
rospy.sleep(0.02)
column_marker = Marker(
type=Marker.CUBE,
id=10+idx,
pose=Pose(Point(-4.5+idx, 0.0, (prob_value*10)/2),
scale=Vector3(0.2, 0.01, prob_value*10),
color=ColorRGBA(0.0, 1.0, 0.0, 0.8))
marker_pub.publish(column_marker)
rospy.sleep(0.02)
def motion_srv_callback(_):
global belief
# Call to Bayes Filter predict step (offset (distance) z = 1)
distance = 1
belief = predict_step(belief, distance, kernel)
# Visualize in Rviz
response = EmptyResponse()
return response
def measurement_srv_callback(_):
global belief
# Call to Bayes Filter correct step (sensor reading z = 1)
likelihood_estimation = likelihood(
corridor_map, z=1, z_prob=light_sensor_accuracy_rate)
belief = correct_step(likelihood_estimation, belief)
# Visualize in Rviz
return response
def main():
# Initialize a ROS node
rospy.init_node('bayes_filter')
global kernel, light_sensor_accuracy_rate
if not rospy.has_param("/odometry_noise_profile"):
rospy.logwarn('Parameter [%s] not found, using default: %s' % (
("/odometry_noise_profile"), "[.1, .8, .1]"))
kernel = rospy.get_param("/odometry_noise_profile", [.1, .8, .1])
# Light sensor accuracy rate, meaning the frequency of correct readings (value between 0.0 and 1.0)
if not rospy.has_param("/light_sensor_accuracy_rate"):
("/light_sensor_accuracy_rate"), "0.9"))
kernel = rospy.get_param("/light_sensor_accuracy_rate", 0.9)
# Subscribe to the ROS topic called "/movement_data"
rospy.Subscriber("movement_data", Int32, movement_callback)
# Subscribe to the ROS topic called "/sensor_data"
rospy.Subscriber("sensor_data", Int32, sensor_callback)
# motion_update service server
motion_update = rospy.Service(
'/request_motion_update', Empty, motion_srv_callback)
# measurement_update service server
measurement_update = rospy.Service(
'/request_measurement_update', Empty, measurement_srv_callback)
# Create a new ROS rate limiting timer
rate = rospy.Rate(5)
# Wait for at least 1 subscriber before publishing anything
while marker_publisher.get_num_connections() == 0 and not rospy.is_shutdown():
# rospy.logwarn_once("Waiting for a subscriber to the topic...")
print(marker_publisher.get_num_connections())
rospy.logwarn("Waiting for a subscriber for: /visualization_marker")
rospy.sleep(5)
# Print node start information
print("Started Bayes Filter node")
print("Waiting for sensor data...")
### Visualize initial belief in Rviz ###
# Execute indefinitely until ROS tells the node to shut down.
# Sleep appropriately so as to limit the execution rate
rate.sleep()
if __name__ == '__main__':
try:
main()
pass
Roberto
