Uncaught ReferenceError: ROS3D is not defined, seems that ros3d.min.js is not correctly loaded
Hi @gxianggm, this seems like out of date. What and where (link) are you attempting this on?
Please carefully follow the instructions in that unit. You should copy the HTML and JS codes supplied and create the ros3d.min.js and the other libraries file in the libs folder.
I just confirmed that this works.
