So I am trying to do the quiz for Understanding ROS 2 Actions and I keep getting an error with 'Import Move' as seen in the screen shot. I am not sure what is going on but Im pretty sure I have my code correct in terms of having it be read correctly.
When you see this kind of error in Python, it means the interpreter cannot locate the code you are trying to import.
For this specific case, it could be two things:
the directory structure of actions_quiz_msg is not correct. Please note that actions_quiz_msg should be a separate package, and should not be nested in actions_quiz.
actions_quiz_msg has not been properly built or sourced.
Please proceed as follows:
Ensure that actions_quiz_msg has been created as a separate package and has the right structure. Also check the actions_quiz package.
Have you compiled the packages successfully? If not, you should do:
