The autograder fails to find the required packages, services_quiz and services_quiz_srv even though they exist. Before running the auto grader, I can see them via "ros2 pkg list | grep services" (See screenshot), but after running auto grader I cannot see them. Also, using the service server and client work when calling their respective launchfile manually, so all should be in order for the quiz. The auto grader should be able to see them at the very least.
What is the output you get when you run the above commands? Was the compilation successful? Please show us the output of those commands here.
Also, it appears you are using symbolic links for some packages. If so, please remove them, because the grader will not be able to resolve those links.
I built the packages one at a time, since services_quiz depends on Spin.srv to be built first.
I am not sure how to remove symbolic links. How can you tell this is a problem? Thanks!
If you didn’t create any symbolic links manually, then don’t worry about this.
I think this is the problem. You should be able to build both packages together.
You should have set services_quiz_srv as a dependency when creating services_quiz. That way, colcon would know it has to compile services_quiz_srv first. Kindly revise your packages so that it works that way (compiling them together).
