Cannot save file if I can't type in the "File name" field. Gazebo open with "gazebo" in terminal and then maximized. Added a couple of models.
It appears to be a very long delay. Or some change of window focus. Eventually, I was able to save the world.
Hi @ivogeorg ,
I have experienced that issue too. It is just the lag in window’s response in the virtual machine.
What I usually do is, I select the path in the Address Bar and I just save the file with the default name.
I will then use the IDE or the terminal to navigate to that folder and make the final changes like creating a folder and moving the file inside or renaming the file, etc.
I hope this tip helps.
