What to do if it shows command not found in the terminal. Is it because I have to install catkin?Or is it because environment is not setup properly
This is happening because you have a extra $ sign before the command, probably from where you copied the code. Please remove it.
Thankyou for the reply. Yes, that was the unnoticed mistake.
