[Bug] Error in TF in RVIZ2
The error is due the fact that no transforms between the robot's frames and the map frames are found
Hi @GiovanniCaramia ,
Welcome to this Community!
By looking at your image, I see that the TF is being advertised correctly.
I think your issue is that your cartographer.lua file has incorrect reference to the tracking_frame parameter.
Check if tracking_frame is set to base_footprint. If not, set it to this frame. This should fix your issue.
Let us know if you still have this issue.
