apparently there is an error en in the example lauch files that are set to be run in the first sections. Neither the initial demo, nor the trajectory_by _name produce any result or movement in the simulation window.
Perhaps that was just a temporary bug, because it all works for me here. Could you please try again and send us a short screen recording of the problem if it happens again?
