[Bug] Final Project Error
course Deep Learning for Robotics
unit Final project
HI, In the final project of this course there is no camera topic transmitted from the robot. I can not get images to feed the deep learning model. Please could you fix this. Thanks
Hello @eblady ,
I’m looking into this issue and confirmed the error. Please allow us some time in order to get it fixed. Meanwhile, I suggest you move and try other courses. I’ll let you know once we have it fixed.
Could tell us what did you do exactly?
Did you install anything? Like pip3 install tensorflow or something like that prior to this?
Hi we just solved the issue. You shoudl be able to see the camera now. Beware that the camera resolution is 2040 by 2040, so your corpings might have to change in order to see the correct part of the image ;).
