The robot doesnt move, the folder in the top left editor is different from the instructions. but more importantly the robot doesnt move.
You need to collapse the build and devel folders (these are collapsed by default), then you’ll see the other one (src).
I see you only typed “forward” in the terminal. You are expected to copy/paste the command given in the notes, and write forward (or any of the other ‘commands’) in front of it (i.e. as a parameter)
