[Bug] Gazebo process dies when using colcon build
Gazebo process dies when using colcon build because of out of memory error
Please try again.
If the problem happens again, it might be a bug in your code, causing a memory leak.
If you require further help, please include a complete output of your terminals indicating the package(s) you were compiling.
