how to fix this rosrun problem as only move_bb8_square.py is not working with rosrun but instead it is working with python
I think you have two different python scripts with the same name. Or maybe the same move_bb8.py file but duplicated. One in move_bb8_pkg/src and the other in move_bb8_pkg/my_scripts
it means that there are multiple executables with the same name in different packages. This can occur if:
so in other terms you have the move_bb8_square.py in multiple locations built as executable
the command is rosrun <package_name><executable_name> so make sure to have the correct package name (a ros package is different than a normal folder)
try to remove any instance of the python file except in your package
Hi @8853897079, to complement the given answers you have to make sure also that the Python script has executable permissions:
chmod +x move_bb8_square.py
Also, Check the Shebang (Interpreter Line): The first line of your Python script should specify the Python interpreter. Ensure your script starts with:
#!/usr/bin/env python3
And the most important you have to make sure that you included the script in the CMakeLists.txt and you compiled and sourced:
install(PROGRAMS
src/move_bb8_square.py
DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
