robotcontrol.turn("counterclockwise", 1.5708, 1) Doesn't this mean the robot should turn 1.5708 (ie. 90 deg) radians in one second?
Hi @professor.herman, yes, you are correct that the method call robotcontrol.turn("counterclockwise", 1.5708, 1) is intended to make the robot turn counterclockwise at a speed of 1.5708 radians per second for 1 second.
You can also check the method definition that is:
def turn(self, clockwise, speed, time):
# Initilize velocities
self.cmd.linear.x = 0
self.cmd.linear.y = 0
self.cmd.linear.z = 0
self.cmd.angular.x = 0
self.cmd.angular.y = 0
if clockwise == "clockwise":
self.cmd.angular.z = -speed
else:
self.cmd.angular.z = speed
i = 0
# loop to publish the velocity estimate, current_distance = velocity * (t1 - t0)
while (i <= time):
# Publish the velocity
self.vel_publisher.publish(self.cmd)
i += 1
self.rate.sleep()
# set velocity to zero to stop the robot
self.stop_robot()
s = "Turned robot " + clockwise + " for " + str(time) + " seconds at " str(speed) + " radians/second"
return s
