I cannot really describe the error as I followed the instructions given in the tutorial. I keep getting this error but I am not sure what to make of it.
Hi @mariellarsanchez ,
Thanks for pointing out this issue.
I think this error is coming from the plant_detector.py python script file.
The line output = self.model(input_tensor) is probably not getting the image in the desired manner.
The python programs might require some exception handling implemented.
But for the time-being, the best way to get this working would be to restart the simulation and restart the programs associated with this exercise/example. The first simulation launches might cause some issues sometimes. So second launch would work well.
Let me / us know if the above suggestion worked for you.
PS: @duckfrost2 Could you please take a look at this issue when you find some time? Thanks in advance!
Hello! @girishkumar.kannan
I solved the issue. It was a relatively silly problem as there was no issue running the executable, but my mistake was that I kept trying to run the file itself not the executable made after building the file.
For some reason mars_rover_systems was failing to build, so it had to be deleted. There was definitely some conflicts there.
Thanks for your help! ![]()
Glad to know that you figured out the solution to the issue on your own.
Please mark your post as the solution so this issue thread can be closed.
