Matplotlib is not installed. Furthermore, the version of Python on this machine is outdated, which prevents me from performing updates or installing the necessary library.
We will see into this right away, thanks for the report
Just test it it and, it works perfectly.
It’s in python 2, NOT python3. If you use python3 it doesn’t work, but I just executed the vector.py example and worked without any issue, please check that or give us more information on what you are doing exactly.
Hello. Thank you.
I have just reviewed and discovered the problem. Initially, I believed it was because Matplotlib was not installed and the version of Python on this machine was outdated, which prevented me from performing updates or installing the necessary library. However, I have found that the real problem is that Matplotlib is not recognized by Visual Studio from The Construct, and it is not a Python failure as I initially thought.
The code works correctly. Matplotlib was flagged, and I thought it was not working due to this misunderstanding. I am new to this world, which caused me to panic.
Thank you very much!
