I was able to get the code working correctly with the TAs and showed this to the TAs, however I couldnt pass the test marking fully, as I got a 9/10. I have Cc'ed the TAs that helped with the issue and saw the robot working successfully for the test it failed. Please what can be done about the scoring
@gt5412
It’s perfectly possible to have your code working but still fail the test, if you do not structure your code exactly as indicated in the instructions.
What you need to do here is show us the point that is failing (based on feedback from gradebot), and how you have met the requirements for that point.
Based on our records, the following is failing:
✖ [15:03:14] [assess] /send_pose_service did NOT respond with 'OK'. Things your can check: - Are you sending the exact word 'OK' from the service server? (mark: 9.0)
