[Bug] PIL module not found
In the module plant_detector.py, the import of the PIL module can not be resolved. As a result, the conversion for the detection model is wrong and plants are not recognized. Looks like there is a problem with the PIL/Pillow module installation.
Have you tried installing it yourself ?
pip install pillow
Hi Khaled07, thank you for your quick reply!
I did try, but gave me the following:
Requirement already satisfied: pillow in /user/lib/python3/dist-packages (9.0.1)
Removing and reinstalling is not possible as:
Pip uninstall pillow
Found existing installation: Pillow 9.0.1
Not uninstalling pillow at usr/lib/python3/dist-packages, outside environment /usr
Can’t uninstall ‘Pillow’. No files were found to uninstall
Please ignore the warning in the IDE unless it’s affecting the running of your code.
We are working on removing this false positive. Apologies for the trouble.
