Seems like rmf package didnot sourced and invisible from user terminal, can someone fix that please?
This can be due to two things:
You removed the build and install by accident and you didnt source the `/home/simulations/ros2_sims_ws/install/setup.bash’ before compiling your ros2_ws
Did you downloa dthat package into the ros2_ws? Is becuas ethat packages is indicated to be downloaded in previous usnits and you have to compile it before any other package that depends on it.
Please let me know if these indications didn’t work ;).
