I am trying to get rviz to load the map I saved but it doesn't load the map, it says "No map received". I made sure my launch file has the .yaml file and its publishing but its not loading for some reason.
import os
map_file = os.path.join(get_package_share_directory('map_server'), 'config', 'turtlebot_area.yaml')
return LaunchDescription([
Node(
package='nav2_map_server',
executable='map_server',
name='map_server',
output='screen',
{'yaml_filename':map_file}
Node(
name='lifecycle_manager_mapper',
output='screen',
{'autostart': True},
{'node_names': ['map_server']}])
from setuptools import find_packages, setup
import os
from glob import glob
package_name = 'map_server'
setup(
name=package_name,
version='0.0.0',
packages=find_packages(exclude=['test']),
data_files=[
(os.path.join('share', package_name, 'launch'), glob('launch/*.launch.py')),
(os.path.join('share', package_name, 'config'), glob('config/*')),
zip_safe=True,
maintainer='user',
tests_require=['pytest'],
entry_points={
'console_scripts': [
Here is how my files are ordered. user:~/ros2_ws/src/map_server/config$ ls
turtlebot_area.pgm turtlebot_area.yaml
