Gazebo world is not shown, but topics exists
The simulations in there, but i saw that there is an issue with the CSS code on the page, you need to:
1 inspect the page in black
Awesome answer Ivan. Thanks for sharing!
We are working to solve this problem so no student needs to do that fix. Thank you anyway for posting your solution, definitely is going to help some people while we deploy the solution. ![]()
Thank you very much for your suggestion, @IvanMurataya
We’ve implemented in an automated way what you suggested here.
So now, when someone has this problem, the system will automatically set the viewport height to 100% in at most 7 seconds.
Thank you also, @robotnik.formacion1, for reporting the error.
#KeepPushingYourROSLearning
