My code worked fine before i submitted it to be controlled. The auto control tells me that the node exits within 15 secs but it never did with me, and now it seems like the pkg cannot be found…
Hi @timottesen,
Can you try to delete install, build and log folders, colcon build, source and tell me if the problem still occurs ?
Can you also post your setup.py file ?
