Helllo,
I followed every specifications (file name, topic name) and the robot moved correctly: avoid the sphere and move forward).
But Gradebot says that it didnt subscribe from /scan topic.
Could you tell me what is wrong here?
I had checked “topic info” while the programme running and it subscribs as shown.
Does anyone else have the same problem and know of a solution?
From what you shared here, the name of your node was incorrect:
- The name of the node was supposed to be
topics_quiz_node, but you named it avoid_sphere.
- This grader suggested this to you in its feedback, and you didn’t act on it:
✖ [20:12:16] [assess] Not subscribed to /scan. I had big plans for this!
- Did you create a subscriber correctly to the topic /scan in your source code?
- Did you name your node correctly in the C++ source? It should be topics_quiz_node (mark: 4.0)
