The file task3.py took too long time to be graded. I would like to ask if it is fine for me to get the certificate since I already got 8/10 without the task3.py being graded. Thank you.
No, the certificate cannot be awarded in this situation because the grading did not end gracefully.
You need to fix task3.py so that it gets graded on time (should be a few seconds). When you create software in the real world, they shouldn’t get stuck this way, so this issue must be resolved.
